WEIMA
Coolant Cleaning System Powered by Compressed Air
Exair’s Chip Trapper for cleaning large coolant sumps removes solids such as chips, swarf and shavings from used liquids.
Exair’s Chip Trapper for cleaning large coolant sumps removes solids such as chips, swarf and shavings from used liquids. The machine vacuums the coolant or other liquids into a 30-, 55- or 110-gallon drum, trapping all the solids in a reusable filter bag. When the flow valve is turned, clean liquid pumps back out. Powered by compressed air, the system features built-in pressure and vacuum relief as well as an automatic safety shut-off valve, and has no motors or impellers. It is equipped with a stainless steel two-way pump assembly, a lever lock drum lid, a 10-ft. vacuum hose, a 20-ft. compressed air hose, a chip wand and a drum dolly. The system is intended for use on machines with sumps, parts washers, tanks and storage containers.
Gardner Business Intelligence
The view from my shop.
Gravotech
WEIMA
