Coolant-Through Toolholders Improves Chip Evacuation
Eastec 2019: Vargus USA’s coolant-through toolholders provide precise flow to the cutting edge and are suitable for high-pressure systems with as much as 1,000 psi.
Vargus USA’s coolant-through toolholders provide precise flow to the cutting edge and are suitable for high-pressure systems with as much as 1,000 psi, according to the company. These holders are said to help reduce cutting edge temperatures to improve tool life, chip evacuation and chip control. The coolant-through toolholders are also supported by the company’s GENius platform, a tool selector and CNC program generator.
Quick-Change Collet Chuck Doubles as Mandrel
The hybrid Comot-AZ quick-change collet chuck from SMW Autoblok can be used for OD machining and can be transformed into an expanding mandrel for ID clamping using the EMX series.
How to Troubleshoot Issues With Tool Life
GenSwiss Releases Redesigned Toolholding System
Its GenQuick quickchange ER system for Swiss-type CNC machines and precision machining equipment has been updated.
