Digital Level Aligns Machine Tools with High Accuracy
The Digi-Pas two-axis wireless Smart Machinist level from Digipas is designed for leveling alignment tasks for metalworking machines, inspection and test equipment.
The Digi-Pas two-axis wireless Smart Machinist level/inclinometer from Digipas is designed for leveling alignment tasks for metalworking machines, inspection and test equipment. It is said to speed alignment time to achieve maximum machine stability, improving dimensional accuracy and output quality.
The level wirelessly displays both X and Y leveling readings via Bluetooth on a smartphone or PC while users adjust the machine’s footings on the floor. This reduces time and improves quality of machine installation, setup and maintenance. It thereby replaces two units of spirit levels and single-axis inclinometers.
Powered by advanced MEMS sensor technology, the level’s built-in vibrometer permits accuracy as high as 1 arcsecond and simultaneously displays 2D angles with vibration measurements. Its accuracy is certified by accredited calibration and test laboratories traceable to NIST, JIS and DIN. When synced with a PC using Digipas software, it enables wireless leveling, real-time data acquisition, logging, diagnostics and analysis. These features make the level useful for installation, setup and maintenance of CNC machines as well as inspection and testing equipment.
