GWS Tool Group
Dynamic Milling Cutter Insures Even Wear
The MD133 Supreme milling cutter from Walter USA is designed for dynamic milling and delivers process reliability, particularly during unmanned operation.
The MD133 Supreme milling cutter from Walter USA is designed for dynamic milling and delivers process reliability, particularly during unattended operation. Its productivity comes from a high metal removal rate and a reduction in machining time. The first in the company’s projected line of dynamic milling cutters, it comes in diameters ranging from 0.25" to 0.75" (6 to 20 mm) and cutting lengths ranging to 5×Dc. The line is designed for operating parameters typical of dynamic milling, such as small width of engagement and a high depth of cut facilitated by a large cutting length. The chipbreaker produces short chips even when working with large cutting depths, the company says.
The cutter is available in two  grades. WJ30RD works well for steel and cast iron, while WJ30RA is designed for stainless steels with secondary applications in ISO S and N. Overall, the cutting system is designed for difficult-to-cut materials or unstable conditions due to the machine, workpiece, or clamping.
The cutter makes full use of the entire cutting length, giving it an even wear pattern. Additionally, heat is dissipated via the chip, improving tool edge life. It works well in both high- and low-volume production environments. With its flexibility, the milling cutter is suitable for the diverse range of tasks required for dynamic milling operations. Typical application areas for the company’s dynamic milling cutter line include general engineering, aerospace, energy, and the mold and die industries.
IMCO
Sumitomo
GWS Tool Group
Ingersoll Cutting Tools
SGS
Horn USA
Kyocera MA90
