GWS Tool Group
End Mill Series for Chatter-Free Machining
Haimer USA’s will display its newly expanded offering of Power Mill end mills.
Haimer USA’s will display its newly expanded offering of Power Mill end mills. The series is made from K20-K40 grade fine grain carbide developed to be matched with the company’s toolholders. The end mill’s geometries utilize flute and helix designs to provide chatter-free, high-end machining.
The series is equipped with integrated Safe-Lock shanks for optional use with the Safe-Lock toolholding technology. Its variable-helix design provides vibration-free machining and a runout accuracy of less than 0.0002". The machines are precision-ground and fine-balanced for consistent and repeatable performance, and maximum metal removal rates. Expanded offerings are available in inch and metric sizes.
The company will also be exhibiting its Duo-Lock modular interface for carbide cutting tool heads and the Safe-Lock tool clamping system. Additionally, the company will display its Power Clamp shrink-fit machines; shrink-fit toolholders and collet chucks; Tool Dynamic balancing machines; 3D sensors; and Cool Flash coolant delivery system.
  • New Modular Tool Options for Small Spindle Milling
  • Buying a Lathe: The Basics
  • Threading On A Lathe
Iscar
IMCO
SGS
GWS Tool Group
Ingersoll Cutting Tools
Sumitomo
Kyocera MA90
