End Mills Suited for Mold and Die Work
OSG will showcase a variety of its tools, including ExoPro PHX deep-feed-radius end mills, and ExoCarb WXL and WXS carbide end mills.
ExoPro PHX end mills are designed specifically to enable moldmakers to achieve improved quality, cost savings and delivery times with their existing equipment. New “spiral gash” geometry is designed to increase edge strength and reduce chip thickness. The company’s WXS nano coating increases hardness and heat resistance. The end mills are available in a variety of lengths and shapes, including ball-end, pencil-neck, long-neck, and corner-radius.
ExoCarb WXL and WXS carbide end mills are designed for rigidity and performance, even in tough materials and milling applications. The WXL is tailored for nonferrous materials and mild steels ranging to 55 HRC, and can withstand temperatures to 1,100°C. The WXS is made for hardened steels such as D2, A2, S7, H13 and CPM. It is capable of milling to 65 HRC and can withstand temperatures to 1,300°C. With their high-precision geometry, the WXL and WXS are said to be well-suited for the mold and die industry, eliminating the need for benching and reworking.
10 Tips for Titanium
Grooving Attachment Streamlines Operation by 75%
A grooving attachment enabled Keselowski Advanced Manufacturing to reduce cycle times by over 45 minutes on a high-value, high-nickel part feature.
