Gurit CBS for the Aston Martin DBS
Out-of-autoclave process mints Class A carbon composite body panels in one-hour mold cycle.
Case Study From: 1/13/2010 CompositesWorld, Bob Griffiths
Fig 4 - hood tool
Fig. 4: Hood curing tool. Source: Gurit
Fig 3 - material chart
Fig. 3: Comparative weight data for the Aston Martin SPRINT CBS materials vs. aluminum and steel.
Bob in Aston Martin
For the Aston Martin DBS, Gurit UK’s new pilot plant manufactures six composite components: The hood outer and inner, the front fenders and the rear decklid outer and inner. Article author Bob Griffiths is at the wheel. Source: Gurit
Fig 2 - schematic of tool
Fig. 2: Schematic of tool, laminate, caul plate and vacuum bag. Layers represent 1) re-usable silicone bag; 2) caul plate; 3) release film; 4) SPRINT CBS96; and 5) nickel-shell tool surface. Source: Gurit
Fig 1 - SPRINT CBS96 laminate diagram
Fig. 1: SPRINT CBS96 Laminate (combined cured ply thickness 1.8 mm/0.07 inch). Laminate layers represent 1) ST86 RE400T single-sided SPRINT; 2) syntactic core (0.7 mm); 3) ST86 RC200T single-sided SPRINT; and 4) SF96 surface film for the exterior surface. Source: Gurit
Fig 5 - rolled edge detail
Fig. 5: Detail of tooling (unassembled) used to achieve a “rolled” edge in composites. Source: Gurit
Fig 7 - CMM inspeciton
Fig. 7: A coordinate measuring machine is used to verify trunk lid dimensional accuracy. Source: Gurit
Fig 6 - bonding fixture
Fig. 6: Hood bonding fixture. Source: Gurit
At its facilities in Newport on the Isle of Wight, located a few miles off the South Coast of the U.K., Gurit (UK) Ltd. has developed a molding process for its trademarked SPRINT material system that is designed specifically to meet the needs of the customer who wants to cure carbon composite structural parts without the long cycle times and cost associated with the use of an autoclave. The SPRINT prepreg system reportedly cures in less than an hour under vacuum pressure.
Gurit recently set up a lean manufacturing facility to prove the concept’s applicability in the real world by manufacturing five exterior body panels for the Aston Martin DBS sports car. The £2 million ($3.2 million) investment has created a 20,000 ft² (2,000m²) pilot facility capable of molding, machining, assembling and painting as many as 45 car sets per week. I was able recently to visit the pilot plant, observe production and assembly of the Aston Martin components and gather the following project data.
Adapting SPRINT for body panel production
To meet the needs of car designers, Gurit materials engineers introduced two features to the standard SPRINT system that are not normally seen in structural carbon fiber-reinforced polymer (CFRP). For one, they’ve added an outer ply of surfacing film that enables production of parts with a Class-A finish — free from pinholes and fiber print-through — straight out of the mold. The other novel feature is a thin (0.7mm/0.03-inch) layer of epoxy syntactic foam, in the middle of the laminate ply schedule, which improves buckling resistance (see Fig. 1). The laminate system, with core and surfacing film, is called CBS, which stands for “Car Body Sheet,” and is produced at an adjacent Gurit prepreg facility and then delivered to the production shop assembled and ready for cutting and molding, thus significantly reducing the layup time. It is claimed that the system yields weight savings of between 56 and 70 percent, compared with steel, depending on whether the reinforcement is a hybrid of glass and carbon or all-carbon. In the latter case, the material is designated CBS SL (Super Light). The weight data for the SPRINT CBS parts is given in Fig. 3 on p. 26 in comparison with the same parts made with traditional automotive materials.
Molding an assembly-friendly second surface
This plant produces the two front fenders, the hood and the trunk lid for the DBS. All feature the CBS system for their outer skin. The hood and trunk lid feature internal stiffening panels, also made made from CBS. (Aston Martin customers have the same high expectations for surface finish on the parts they can see whilst putting their luggage in the trunk or checking the oil level under the hood, as they do when looking at the exterior body panels of their beautiful cars!)
Gurit is currently using 35 direct workers on two shifts, with 20 indirect workers who perform accounting, quality-control and manufacturing engineering support functions for this team. The production facility is divided into nine manufacturing cells:
  • Kit cutting
  • Kit assembly
  • part layup and cure
  • Inspection, de-flash and paint prep
  • CNC trim and drill
  • Assembly
  • Paint
  • CMM inspect
Following kitting and layup, the parts are cured in oil-heated nickel-shell tools (see Fig. 4) supplied by Weber Manufacturing Technologies Inc. (Midland, Ontario, Canada). Parts are layed up and cured under vacuum in one location, thus avoiding the need to move tools around the production shop. All parts are cured with an outside Class-A finish and an inside tooled finish suitable for bonding components, such as stiffeners, to the inside of the hood and boot trunk lid. The high quality of the inner surface is achieved by means of a glass fiber-reinforced caul plate. On parts with a one-piece caul plate, the plate has two functions. It ensures a good, tool surface-like finish, and it also acts as the vacuum medium, avoiding the cost and time required to use vacuum consumable materials, such as reusable silicone rubber bags. On the more complex parts that have multipiece caul plates, a silicone bag is used in addition to the caul plates to seal the entire layup (see Fig. 2, previous page, top right).
Getting the edge on metal parts
One advantage of metal body panels is that the edges can be easily “rolled” to give a nice smooth feel to any edge that the customer is likely to see or touch, such as a wheel arch or trunk lid lip. To reproduce this finished edge, Gurit developed a technique for folding over the edge of the laminate against a loose edge-tooling bar. This achieves the same thick, rounded edge that is achieved in metal panels and also avoids the cost of postmold machining of the edge. The quality of the as-molded edge on the CBS parts is comparable to that on previous metal parts — it looks like a metal rolled edge and is free from resin richness or air bubbles (see Fig. 5).
The inner and outer panels of the trunk lid and hood are bonded at room temperature, in complex fixtures, which determine the final shape of the very stiff panel assembly. (See Fig. 6). After this assembly step, all parts are inspected for dimension accuracy on a coordinate measurement machine (See Fig. 7) and then visually inspected for surface finish. Gurit says they have to be right the first time — no repairs are allowed on external surfaces.
The finished parts are primed, then placed in special containers and shipped directly to the Aston Martin assembly line. The parts undergo no further inspection until after they are fitted to the car
Assessing the effect on assembly
At the Aston Martin assembly plant, the CBS parts are integrated into the car’s structure. One of the real tests of whether or not composites have a long-term future in automotive production is their utility here. Automakers balk at new materials or methods if they produce parts that subsequently require special treatment. I saw no evidence of this with Gurit’s CBS parts. Other than their color, the metal and composites parts were indistinguishable in terms of their handling. Aston Martin’s operators seemed unaware of whether the panels they removed from the line-side containers were made of one material or the other. (However, to this observer, one curious effect on the car assembly line was that, before the cars are given their final coats of paint, the Aston Martin is a patchwork of composite panels primed in gray, and therefore looking like metal, and aluminum panels primed in black, looking like CFRP!)
The Aston Martin parts project represents a significant milestone in efforts to adapt carbon composites for series production in the automotive environment. Its success in a necessarily unforgiving Class A parts program supports Gurit’s ambition to expand its business into manufacture at higher volumes, based on the lessons learned from this very impressive pilot plant.
Editor's Picks
Tooling for Aston Martin components to be supplied by Weber Manufacturing
Weber Manufacturing Technologies will supply NVD tooling to Gurit for production of composite components on Aston Martin cars.
Carbon car hood: Class A and cost-effective
Resin film infusion, electroformed nickel tooling meet Aston Martin quality and cost targets.
Gurit seeks to boost carbon fiber auto parts production
Gurit's new U.K. facility that makes parts for the Aston Martin DBS is starting to pay dividends.
Editor's Picks
Weber Manufacturing Technologies will supply NVD tooling to Gurit for production of composite compon...
Resin film infusion, electroformed nickel tooling meet Aston Martin quality and cost targets....
Gurit's new U.K. facility that makes parts for the Aston Martin DBS is starting to pay dividends....
