Okuma
Jet Coolant Nut Directs Fluid to Cutting Edge in Micromachining
Big Kaiser’s Mega micro coolant nut is said to provide precise coolant supply to micro cutting tools applications at high speeds when using the Mega micro chuck 6S.
Big Kaiser’s Mega micro coolant nut is said to provide precise coolant supply to micro cutting tools applications at high speeds when using the Mega micro chuck 6S. The coolant nut is designed for high-speed micromachining of parts with diameters ranging to 6 mm. The company says that the micro nut optimizes milling performance and increases tool life compared to standard nuts.
Without precision coolant, chip jamming can be a problem, causing machine stoppages, service callouts, increased tool wear and poor surface finish, the company explains. The company says that the Mega micro coolant nut is designed to prevent such challenges and get the coolant to the cutting tip.
Okuma
MMS Top Shops
Okuma
