Keyless Drill Chucks Ensure Precise Hole Sizing
Albrecht’s precision drill chucks, available from Royal Products, are designed to ensure precise hole sizing and extend drill life.
Albrecht’s precision drill chucks, available from Royal Products, are designed to ensure precise hole sizing and extend drill life. These keyless chucks are said to grip tighter the harder they’re used, with the jaws maintaining position parallel to centerline, providing uniform gripping force. The diamond-impregnated jaws eliminate drill slippage and jaw damage that can occur when using carbide or hardened-shank drills. Each of a given chuck’s more than 20 components is air-gage qualified during manufacturing. Further promoting chuck quality, each chuck is checked with four to six diameter-test pins at two locations on each pin during assembly.
Five Common Mistakes Shops Make with ER Collets (And How to Prevent Them)
Collets play a crucial role in the machining process, so proper tool assembly and maintenance is important. Here are five potential pitfalls to avoid when using ER collets.
GenSwiss Releases Redesigned Toolholding System
Its GenQuick quickchange ER system for Swiss-type CNC machines and precision machining equipment has been updated.
