Laser Plus Automation Package Enables Lights-Out Production
Trumpf’s TruLaser 2030 integrates an energy-efficient, 4-kW TruDisk fiber laser for flexible and economical 2D laser cutting on a variety of materials and thicknesses.
Trumpf’s TruLaser 2030 integrates an energy-efficient, 4-kW TruDisk fiber laser for flexible and economical 2D laser cutting on a variety of materials and thicknesses. The machine has a 60" × 120" working area, and to boost productivity, it will be displayed with a flexible automation system for loading/unloading. The laser cutting system can be equipped with either a standard pallet changer or the LiftMaster Shuttle for lights-out production.
A user-friendly touchscreen interface graphically displays the program and all essential information and is designed for experienced and novice operators.
