Material Handling System for High-Volume Finishing Operations
The Therma-Tron-X SlideRail Square Transfer (SST) material handling system features a compact footprint and is designed to perform high-volume finishing operations using less space than that required by traditional monorail systems.
The Therma-Tron-X SlideRail Square Transfer (SST) material handling system features a compact footprint and is designed to perform high-volume finishing operations using less space than that required by traditional monorail systems. The system is said to reduce electrocoat tank charge costs, utility costs and chemical consumption. Featuring immersion pretreatment capability, the system is constructed from stainless steel and has totally enclosed process tanks.
View From My Shop Video 1: A Deep Dive Into Automation with Advance CNC
Advance CNC leverages multiple forms of automation to increase its milling machines' productivity. Learn more in this episode of The View From My Shop.
Beyond the Machines: How Quality Control Software Is Automating Measurement & Inspection
