Metalworking Vacuum
The single-phase WSS 100 and WST 100 DV industrial vacuums are designed to collect and discharge oil and coolants in metalworking applications.
The single-phase WSS 100 and WST 100 DV industrial vacuums are designed to collect and discharge oil and coolants in metalworking applications. The high-quality, durable vacuums collect, separate, discharge and recycle as much as 100 liters of metalworking fluids to save time and reduce costs, the company says.
The WSS 100 is a base model for coolant/chip collection with a gravity-fed drain valve. The WST 100 DV is equipped with a diverting valve that reverses the flow of air to pump out the tank. It is also equipped with a tilting motor head for easy access to the internal chip baskets.
