GWS Tool Group
New Cutting Tool Range Meets Productivity Needs of Industry 4.0
Iscar is displaying a selection of its new Logiq cutting tool range designed to maximize machining processes and optimize performance.
Iscar is displaying a selection of its new Logiq cutting tool range designed to maximize machining processes and optimize performance. Integrating Industry 4.0 standards, the tool lines are said to meet today’s machining center demands for increased productivity.
The Logiq fast-feed milling lines feature indexable cutters, solid carbide end mills and Multi-Master tools with replaceable cutting heads. Logiq4Feed enables rough milling at high metal removal rates and incorporates a narrow double-sided insert with four cutting edges. Mill4Feed is a family of tools carrying square, single-sided inserts with four cutting edges, designed for machining almost any type of metals. The Tang4Feed shell mill family is based on the tangential principle of insert clamping to ensure a highly rigid structure and impressive ramping down abilities. Micro3Feed and NanFeed use triangular inserts and feature minimal diameters.
Other highlights include Logiq3Cham, which significantly improves drilling productivity,  Logiq4Turn for enhanced performance in general-duty turning operations, Logiq8Tang, a 90-degree square milling shoulder, and Logiq5Grip, a high-efficiency solution for parting and grooving.
GWS Tool Group
Iscar
Sumitomo
Ingersoll Cutting Tools
Horn USA
SGS
IMCO
Sumitomo
