Paper Filter Extends Cutting Fluid Life
Capable of processing as much as 130 gpm, PRAB’s Paperbed filter is suitable for ferrous and nonferrous metals, as well as organic and inorganic contaminants such as glass, rubber and plastic.
Capable of processing as much as 130 gpm, PRAB’s Paperbed filter is suitable for ferrous and nonferrous metals, as well as organic and inorganic contaminants such as glass, rubber and plastic. The filter is available with low- to medium-stock media and can also be equipped with an integral magnetic separator for larger-particle capture of ferrous metals. The drum-type paper bed filter requires less floor space than a traditional filter unit, and can help reduce operating costs by recycling and reusing spent coolant. Additionally, filtering coolant and metalworking fluids helps to control bacteria and improve quality of finished parts, the company says.
High-Speed Videos Analyze Machining Processes in Fine Detail
Blaser Swisslube captures the machining process, chip formation and behavior of its Synergy 735 metalworking fluid through high-speed, macro photos and videos.
Hennig Inc. Acquires Industrial Coolant Systems
ICS develops and field tests high-pressure coolant systems, coolant filtration systems and other machine tool solutions.
STLE Hosts Co-Branded Tribology, Lubrication Events
The 2023 STLE Tribology Frontiers Conference and Tribology & Lubrication for E-Mobility Conference will provide attendees with two opportunities to share and learn the latest tribology and lubrication engineering science.
