The PipeWorx welding system is an easy-to-use, multi-process welding solution designed to improve pipe welding quality and productivity for fabrication shops, the company says. It provides one-button, quick change-over between processes. Cables remain connected to the power source and do not need to be switched for the different welding processes. Stick, TIG, flux cored and MIG processes are each optimized for pipe welding. The system includes RMD and Pro-Pulse processes, which enable new welders to produce code-quality welds quickly and with less training, the company says.
