Ingersoll Cutting Tools
Plunge-Milling System for Finishing
LMT Kieninger will display its SpeedLift milling head system designed for finishing passport and guide surfaces.
LMT Kieninger will display its SpeedLift milling head system designed for finishing passport and guide surfaces. According to the company, the plunge-milling system features a minimum of components, making it possible to adjust the cutters precisely. Features include form- and force-fit cartridge connections, high-precision in axial and radial run-out and a CBN cutting grade for maximum cutting speed.
  • Tungaloy Expands Line of Barrel-Shaped End Mills
  • How to Mitigate Chatter to Boost Machining Rates
  • Best Practices: Machining Difficult Materials
GWS Tool Group
Iscar
Horn USA
Sumitomo
IMCO
SGS
Sumitomo
