Rotary Positioners Facilitate Controlled Turning
IMTS 2018: Strong Hand Tools has updated and improved its BuildPro rotary positioner.
Strong Hand Tools has updated and improved its BuildPro rotary positioner. Horizontal mounting of welding tabletops to the positioner enables plane rotation. The gear-driven free-turning mechanism facilitates operation and improves stability. The mechanism also enables controlled turning and positioning in 15-degree increments with positive manual locking.
Adjustment plates help shift the center of gravity when working with tall or heavy parts. This enables easier rotation of assemblies as much as 90 degrees from horizontal. Tabletop position can be adjusted at 1" increments.
Adjustable outriggers improve stability when working with taller assemblies and can be retracted when not required.
