Sandvik Coromant's CoroBore BC Performs Semi-Finishing and Chamfering
Sandvik Coromant’s CoroBore Boring Combination (BC) is designed for high-volume applications.
Sandvik Coromant’s CoroBore Boring Combination (BC) is designed for high-volume applications, performing semi-finishing and chamfering in automotive, general engineering and construction equipment applications.
Cutting diameters range from 20 to 200 mm (0.787" to 7.874"), while tool length ranges to 400 mm (15.75"), depending on the coupling size. Coupling options include Coromant Capto, HSK Form A and ISO 9766 as well as ISO/Mas-BT/Cat-V tapers. The range of supported coupling models and sizes enables direct integration with the machine’s spindle interface, thus eliminating the need to use a separate basic holder.
CoroBore BC insert-carrier solutions use CoroBore cartridges. Compared to fixed-insert pockets, this configuration is said to enable easy and efficient cartridge changes. The cartridges come in three configurations: radially and axially adjustable, axially adjustable only, and non-adjustable. All cartridge options are equipped with coolant nozzles capable of accommodating coolant pressure ranging to 80 bar (1,160 psi).
In addition to standard ISO inserts, CoroBore BC boring tools can be fitted with CoroBore 111 inserts, which come with optimized grade options for medium and rough boring. The Sandvik Coromant insert program offers productive geometries and grades for all types of materials and boring operations.
Walter Extends Line of Precision Boring Tools
The new boring tools employ modular components such as cartridge holders and extensions, which are matched to the system, utilize an extensive range of indexable inserts suited for precision boring and can be used for all material groups.
Kay Engineering's Gundrilling Machine Performs Range of Operations
Kay Engineering’s DeHoff 20144 is used to perform gundrilling, pull boring, roller burnishing and thread tapping.
Custom PCD Tools Extend Shop’s Tool Life Upward of Ten Times
Adopting PCD tooling has extended FT Precision’s tool life from days to months — and the test drill is still going strong.
