Multi-axis machining with Fusion
Simulation Helps Optimize CNC Machining
Spring Technologies will demonstrate its NCSIMUL Solutions 10, an all-in-one digital suite.
Spring Technologies will demonstrate its NCSIMUL Solutions 10, an all-in-one digital suite. The company will focus on its most popular modules in the suite, the NCSIMUL Machine and NCSIMUL CAM. With this software, users can simulate, verify, optimize and review machine programs based on the characteristics of the machine tools. According to the company, 3D graphics help to avoid machining crashes while algorithms and embedded process-based knowledge enable cutting conditions to be optimized. The software is said to reduce the time spent on debugging programs and prevent the risk of spindle collision, tool breakage and scrap. It is also designed to improve cycle times and optimize processes.
Also on display will be the NCSIMUL CAM. This module enables users to change the target machine without reprogramming efforts.
SmartCAM
Siemens Zel X
Surface finishing in Fusion
HCL CAMWorks 2024
SmartCAM
