Straight, Angle Heads Offered with Through-Coolant Features
Heimatec now offers through-coolant features on all of its line items including live tools, angle heads and multi-spindle drill heads.
Heimatec now offers through-coolant features on all of its line items including live tools, angle heads and multi-spindle drill heads. The technology enables faster, cleaner cutting on larger and deeper parts where the buildup of chips and excess heat are significant challenges. The company offers through-coolant designs with pressures as high as 1,000 psi on straight-head and 2,000 psi on angle-head tools. A full range of styles and pressures is available.
Big Daishowa Chuck Eliminates Chatter in Milling Operations
The Mega 12DS chuck is designed for trochoidal milling with anti-vibration end mills.
Haimer USA Models a Streamlined Toolroom
Haimer USA is celebrating its 20th anniversary with a live demonstration of its digital toolroom. Find out more past the aluminum panther.
