Swiss-Type Entry-Level Machine Offers Flexibility
Tornos offers its CT 20 entry-level bar turning machine, designed for creating simple to moderately complex components.
Tornos offers its CT 20 entry-level bar turning machine, designed for creating simple to moderately complex components. The 20-mm machine is said to offer a high level of flexibility as well as rigidity with a stable cast iron frame. The turning machine can be configured with five linear axes and two C axes, and supports two independent tool systems. The machine features a modular tooling system and can accommodate as many as 26 tool positions. It can be equipped with as many as 10 high-power drills.
  • Palmgren Launches Combination Bench Lathe, Mill
  • A New Milling 101: Milling Forces and Formulas
  • When Organic Growth in Your Machine Shop Isn’t Enough
Gardner Business Intelligence
