Specialized Plastic Packaging for Cutting Tools!
Threading Shank Holders Deliver High-Pressure Coolant to Cutting Edge
Seco Tools introduces Jetstream Tooling high-pressure coolant technology for threading shank holders.
Seco Tools introduces Jetstream Tooling high-pressure coolant technology for threading shank holders. The range includes shank holders for external applications, boring bars for internal applications and GL-heads for use with the company’s Steadyline boring bars.
The thread-turning holders deliver a concentrated, high-pressure (up to 3,988 psi) jet of coolant through a hose connection to the optimal position, close to the cutting edge. Unlike flood coolant, high-pressure coolant can penetrate the heat vapor barrier that develops on a cutting tool and workpiece in the cut zone. This technology can also be used to guide or steer chips away from the cut and increase tool life, even with minimum coolant pressure.
The holders are capable of breaking tough threading chips on parts made of titanium and similar materials, increasing tool life. When threading steel and stainless steel, the improved chip control can increase cutting speeds by as much as 60 percent without compromising thread surface quality, according to the company.
The thread-turning holders are available in 16 external, 28 internal and 14 GL-head types in insert pocket sizes 16, 22 and 27.
Iscar
Horn USA
Sumitomo
Ingersoll Cutting Tools
GWS Tool Group
SGS
Iscar
