Toolholder Enables High-Production Tapping
Emuge’s SpeedSynchro toolholder features an integrated transmission designed to optimize thread production on CNC machines with synchronous spindles.
Emuge’s SpeedSynchro toolholder features an integrated transmission designed to optimize thread production on CNC machines with synchronous spindles. The integrated transmission is combined with SoftSynchro minimum-length compensation to efficiently work with high cutting speeds and a relatively low synchronous machine tool speed, compensating for synchronization errors during the threading process. According to Emuge, the toolholder offers simple programming and as much as 40 percent time savings because of shorter thread production cycles resulting from fast acceleration and cutting speeds. The holder is suitable for high-production tapping and is said to improve tool life and thread surface quality.
Making the Most of Mixed Toolholder Assemblies
While nearly all ER systems will have cross compatibility, they’ll have small differences across manufacturers that make their implementation at the shop level not as standard.
T.J. Davies Retention Knobs Maximize Cutting Tool Life
