Toolholding System Improves Tool Connection Rigidity
Parlec’s SimulFit dual-contact taper toolholding system is available on ER collet chucks, shell mill holders, end mill holders and milling chucks.
Parlec’s SimulFit dual-contact taper toolholding system is available on ER collet chucks, shell mill holders, end mill holders and milling chucks. The full line of toolholders is offered for CAT and BT, and the system can be used just like any standard toolholder, the company says. Designed to improve performance, the SimulFit system offers improved rigidity of the tool connection with contact on the spindle face and taper. Its stiffer connection makes it suitable for high-speed machining applications, especially for use in heavy milling or long-reach systems.
Quick-Change Collet Chuck Doubles as Mandrel
The hybrid Comot-AZ quick-change collet chuck from SMW Autoblok can be used for OD machining and can be transformed into an expanding mandrel for ID clamping using the EMX series.
How to Troubleshoot Issues With Tool Life
