Variety of Angle Heads Enable Higher Tool RPM
Koma Precision offers custom-designed angle heads by Alberti, including fixed angle heads, offset angle heads, multiple-output heads and long-reach angle heads.
Koma Precision offers custom-designed angle heads by Alberti, including fixed angle heads, offset angle heads, multiple-output heads and long-reach angle heads. All Alberti angle head spindles are made from one solid piece of hardened steel that increases resistance to bending stress. This also enables the tools to reach higher rpm without vibrations, resulting in greater speed and precision. According to the company, the angular contact bearings provide the concentricity and stability required to achieve higher performance of machining operations.
