Vertical Pick-Up Lathe for Small Components
Emag will display its VL 2 vertical pick-up turning machine for small chuck components ranging to 100 mm in diameter and measuring as long as 150 mm.
Emag will display its VL 2 vertical pick-up turning machine for small chuck components ranging to 100 mm in diameter and measuring as long as 150 mm. The pick-up spindle automatically loads the machine with raw parts collected from an integral conveyor belt. The machine itself features a polymer concrete Mineralit base for improved damping and increased stability, and is equipped with a 12-station turret for flexibility.
Okuma
High Accuracy Linear Encoders
Okuma
