GWS Tool Group
VIDEO: Pocketing Steel - 0.030” DOC
with Toroid End Mill and RHINO-CARB™ Inserts from Dapra
(Sponsored Content) This video demonstrates Dapra's 1" Toroid End Mill executing a pocketing routine in steel. The material is 4140PH (30 Rc), and the machine tool used is a Fadal 4020 with a 40-taper spindle with .030" DOC.
Loading the player ...
Pocketing Steel - .030” DOC with Toroid End Mill and RHINO-CARB™ Inserts from Dapra
This video demonstrates Dapra's 1" Toroid End Mill executing a pocketing routine in steel. The material is 4140PH (30 Rc), and the machine tool used is a Fadal 4020 with a 40-taper spindle.
This particular pocketing routine utilizes a smaller IC insert (3/8") at a fine pitch for more feed capability at a lighter depth of cut. This method is usually preferred on lighter-duty (40-taper, linear ways) machines, as it allows the machine to function within its designed capabilities.
The parameters for this video are:
Pocketing Steel - 0.030" DOC
1" Toroid End Mill - 3 Flute
H13 Material
700 SFM (2700 RPM)
.022" IPT (180 IPM)
.030" DOC
60% WOC
40 Taper VMC
For more cutting demonstrations, please visit Dapra’s Tool Demo Site (http://www.dapra.com/tech/videos.htm)
Horn USA
Iscar
SGS
Ingersoll Cutting Tools
IMCO
GWS Tool Group
GWS Tool Group
