VMC Accommodates 12 Tool Positions
Emag’s VM 9 vertical turning center is designed to machine chucked components with a maximum diameter ranging to 450 mm and features a tool turret that can be fitted with up to 12 tool positions.
Emag’s VM 9 vertical turning center is designed to machine chucked components with a maximum diameter ranging to 450 mm and features a tool turret that can be fitted with up to 12 tool positions. It can also be equipped with driven tools to carry out drilling or milling operations. An integrated probe ensures continuous quality control of the workpieces, making the VM 9 well-equipped for a variety of production tasks and workpiece formats.
The VL series, with a modular inverted vertical lathe design, is also available. These modular machines are especially useful for the manufacturing of medium and large batch runs.
