WEIMA
Water-Glycol Hydraulic Fluid Resists Fire
Quaker Chemical’s Quintolubric 702-46 RD fire-resistant hydraulic fluid is a water-glycol formulation designed to increase safety, reduce maintenance and extend product life.
Quaker Chemical’s Quintolubric 702-46 RD fire-resistant hydraulic fluid is a water-glycol formulation designed to increase safety, reduce maintenance and extend product life. The fluid offers minimal foaming and a high viscosity index, and contains additives to support water hydraulic equipment by preventing corrosion, inhibiting bacterial growth and extending the component life. It is intended for use in hydraulic systems requiring fire-resistant fluids and is said to extend pump life even in systems operating under high pressure or in overloaded hydraulic systems.
High Accuracy Linear Encoders
Gravotech
The view from my shop.
WEIMA
