A Machinist’s Tweets
Here is a twitter feed MMS Editor Pete Zelinski enjoys. A machinist occasionally tweets about what his work is like. It's a fun glimpse into the job.
Richard Mercier has been a machinist of more than 25 years, and his father was a machinist, too. Currently working for Soleras Advanced Coatings (a maker of equipment for physical vapor deposition), he occasionally pauses to tweet about what the work of a machinist is like. The result is one of the Twitter feeds I enjoy—a steady stream of glimpses into the craft of someone who values the attention and skill he gets to apply every day. Find him at @mistermachinist. Here is a selection of his tweets:
Well, had a good day machining today. Managed to save a part that was sawcut right to length. Had to machine both ends square. Just made it.
Machining a 5-inch dia. pipe 1/8 inch wall @6ft long, getting lots of vibration, having to machine it in 18-inch sections with steady rest.
We normally use a lot of aluminum jaws, which are nice because I often re-cut my jaws to make sure they are true and the right size.
I like to keep a log of the work that I'm doing each day. It's nice to be able to look back and see how you did it the last time.
Today I modified my magnetic base with a 600-mm-long rod to mount my indicator on for a special job on one of our bigger machines.
I always put special notes in my programs to let others know why I did things that way. I had to machine a dimension oversize for clearance.
Always read your blueprint carefully. I had a program where a groove was omitted and it was because the dimension lines crossed on the print.
I had to drill a 1-inch hole in a pc of stainless steel. I actually step drilled 3 drills to work up to size. It cut easier and with less heat.
Being a good machinist takes a lot of hard work and patience. Sometimes you can only go so fast, and knowing that means a lot.
Can Connecting ERP to Machine Tool Monitoring Address the Workforce Challenge?
How to Grow the Business with Real-Time Job Status Data
Will the “Great Resignation” Become an Opportunity for Manufacturers? Get Ready for the Returning 3 Million
The Great Resignation will become a Great Reapplication when employees currently able to stay out of the workforce return to it looking for something better. Machining employers that are already evaluating candidates for fit, without demanding specific skills coming in, might be positioned well to draw upon this wave.
