3 Design Elements for Effective Turning on a 5 Axis Machine
Here are three design elements that enable this five-axis machine to effectively turn workpieces, even if they aren’t symmetric.
The rotary table balance control system on this five-axis machine enables 600-rpm turning of non-symmetric parts weighing as much as 8,818 pounds.
I like to use numbered or bullet lists in my articles. These visual tools make it easier for readers to quickly scan an article for relevant information. It also makes the article shorter and easier to digest, in part because there’s no need to include transition sentences taking the reader from one paragraph to the next. Instead, key points are provided in meaningful little portions.
In a recent print article, I wrote about three design elements said to enable the MCT five-axis machine platform from Burkhardt + Weber, part of Industrias Romi SA, to be effective at turning operations. These include:
- Turning tool adapter (Because turning with a tool in the main spindle limits production and damages bearings.)
- Table balance control (Because parts to be turned on a five-axis machine often aren’t symmetric.)
- Thermal isolation system (Because introducing heat isn’t helpful here.)
When Too Many Customers Spoil the Part
Duo CNC used to take on as many customers as the shop could handle. But when growth stalled, a top-down audit by the company’s general manager revealed that its customer base was inhibiting growth — and causing the shop to be less efficient and productive.
