10-kW Fiber Laser Platform Provides High Output
Bystronic’s ByStar Fiber laser cutting machine with 10-kW fiber laser is being shown at FABTECH this month.
Bystronic’s ByStar Fiber laser cutting machine with 10-kW fiber laser is being shown at FABTECH this month. The company says that the ByStar Fiber’s high machine dynamics and process reliability ensure high parts output and cutting quality with a range of materials and sheet thicknesses. Built entirely for fiber laser cutting, the ByStar 3015 Fiber laser will be shown with the ByTrans Extended automated material loading/unloading system.
