Accuracy Achieved By Milling On A Magnet
Trilogy Systems ran into a major manufacturing hurdle as the length of its motors increased. The linear motor body comprises a U-section made up of three precision-machined mild-steel plates into which the magnets and coil assembly for the motor are installed.
Case Study From: 11/15/1998 Modern Machine Shop
Trilogy Systems, a leading manufacturer of high accuracy linear motors used for positioning tables in the semi-conductor industry, ran into a major manufacturing hurdle as the length of its motors increased. The linear motor body comprises a U-section made up of three precision-machined mild-steel plates into which the magnets and coil assembly for the motor are installed. As motors became longer over the years, it became increasingly difficult to maintain accuracy using vises to fixture the steel plates. And with the acquisition of a new mill with the capability to machine motor bodies up to 120 inches in length, it became clear that the battle of fixturing in vises had been lost.
Bruce Beakly, President of Trilogy and chief engineer of the Trilogy linear motors, was aware of the holding power available from magnetic systems and turned to WEN Technology for assistance with a magnetic workholding system for his milling requirements. The solution chosen was a set of Bakker permanent magnetic chucks. Since the parts to be held were thin, it was imperative that a fine pole distribution be used so that the magnetic energy would be held within the part and not cause chip retention problems—which could cause damage to the milling cutters—or reduced holding power. For the linear motor bodies which have a finished thickness of approximately 0.25 inch, the Bakker Standard Pole series of permanent magnetic chucks provided the best combination of features: magnetic energy is held within the workpiece, a holding force of 116 psi is achieved, and thermal stability is maintained.
The choice of permanent magnet chucks for such a large milling table—12 by 120 inches—versus electro-magnetic chucks might at first appear rather unusual. However, the fine pole distribution, full magnetic saturation, ease of installation, reliability and thermal stability of the permanent magnet design proved to be clear deciding factors.
Another factor in machining the motor body components was to be able to machine the parts complete in one setup. In particular, it was necessary to mill both ends, all details on one face and drill through for assembly fastener access. Again, the magnetic solution proved highly versatile with a laminated wear plate used to support the part. Through drilling is accomplished by drilling into this disposable plate thus minimizing setups and helping to maintain accuracy.
"In the old days, we were quite good at setting up 24-inch motor plates in vises," said Production Manager Larry Floro. "But when it came time to set up 120 by 2 by 0.25 inch motor frame plates in vises, there was just no way. If we got it straight, it wasn't flat. If we got it flat, it wasn't straight. And if we could get it straight and flat, it wouldn't stay that way during machining.
"With the magnets, I have a disposable face plate which has been qualified to the machine," said Production Manager Larry Floro. "We can lay the plates down in sets, turn on the magnet and cut. Net result is a set of motor plates that are matched and within our manufacturing tolerances every time Any style, any size: just lay the plate down, load the program and cut."
For Trilogy Systems, the answer to reduced setup time and improved accuracy has proven to be magnetic chucks on their mills.
WEN Magnetics
MMS Zones
WEN Magnetics
Zones
Supplier Categories
Loading the player ...
There's more on workpiece holding and positioning in the Techspex Resource Center.
Self centering vise is a cost effective and universal workholding method for five sided machining.
