Okuma
Five-Axis Mill Features Linear Motor Technology
The Mikron HSM 600U LP high-speed milling center from GF AgieCharmilles uses linear motor technology to provide simultaneous five-axis, high-speed machining.
The Mikron HSM 600U LP high-speed milling center from GF AgieCharmilles uses linear motor technology in the main machine axes and optimized direct-drive motors for the B and C axes to provide simultaneous five-axis, high-speed machining and deliver high precision and superior part surface finishes. The machine’s 36,000-rpm vector spindle is designed to improve surface finish and part detail while reducing machining time for semi-finishing and finishing operations.
The machine can accommodate larger workpieces for a variety of applications, including hard metal machining. The rigid design features X- and Y-axis travels measuring 31.49" and 23.62". A polymer granite portal and base are said to increase vibration damping capabilities. Additionally, high-strength cast iron comprises the worktable and X-, Y- and Z-axis slides, which are reinforced by longitudinal ribs and wide sections.
The milling machine is suited for prototype production, die making, and fully automated, low-volume serial production in which accuracy and surface finish are critical. With acceleration of 32.81 ft./sec2, the machine can achieve programmed feed rates of 196 ft./min. in the simultaneous operation of serial production.
A cooling unit in each of the linear axes and in the round swivel unit systematically draws heat out of the machine, creating geometric stability and increased repeatability of movement guidance.
Okuma
High Accuracy Linear Encoders
Gardner Business Intelligence
Okuma
