Okamoto
Handheld Pencil Grinder for Precision Applications
Dynabrade’s air-powered, variable-speed pencil grinder adjusts from 35,000 to 60,000 rpm to suit a variety of precision grinding applications, including deburring, finishing and engraving.
Dynabrade’s air-powered, variable-speed pencil grinder adjusts from 35,000 to 60,000 rpm to suit a variety of precision grinding applications, including deburring, finishing and engraving. It is suitable for turbine blade, tool and die, medical implants and other applications.
The tool features a 1/8" collet, and accepts carbide burrs and mounted points. An adjustable flow control with a dial sets the speed, and the tool remains at the desired speed until it is changed. The spindle lock features a through-hole for quick accessory change. An overhose assembly helps direct air away from the operator, while the ergonomic tactile grip enables nonslip, comfortable operation, the company says.
Okamoto
Supertec PMGII Grinders
MMS Top Shops
Supertec Machinery celebrates 70 years anniversary
