High Speed Roughing Strategy Extends Tool Life
Delcam will launch its Vortex strategy for high speed area clearance, an enhancement to the company’s 2014 PowerMill CAM system for high speed and five-axis machining.
Delcam will launch its Vortex strategy for high speed area clearance, an enhancement to the company’s 2014 PowerMill CAM system for high speed and five-axis machining. Designed for use with solid carbide tooling, the strategy is suitable for two- and three-axis roughing, 3+2-axis area clearance, and rest machining based on stock models or reference toolpaths.
Vortex is fully integrated with PowerMill’s step-cutting strategy for area clearance. The strategy automatically generates extra toolpaths to remove additional material for minimal terracing. According to the company, toolpaths are calculated for more efficient machining and minimized air moves with a controlled engagement angle for the complete operation. The strategy is said to decrease cycle times, lengthen tool life and prevent chipping of the flutes.
Integrated CAD/CAM Promotes Process Efficiency, Traceability
High-requirement markets are not only searching for good parts — they're searching for proof of good parts. CAD/CAM software can help.
Finally, A Comprehensive Software Solution Designed for Small Job Shops
Improve Machining Efficiency Through Digital Twin Simulation
Full simulation of a machining cycle using digital twins can not only identify crashes before they happen, but provide insights that enable the user to reduce cycle times.
