Tooling Package for Increased Productivity
GenSwiss offers its Lous Belet SA precision carbide Expert series tooling packages designed for aluminum, brass, titanium, stainless steels and composite material groups.
GenSwiss offers its Lous Belet SA precision carbide Expert series tooling packages designed for aluminum, brass, titanium, stainless steels and composite material groups. The packages incorporate improved geometries and coatings for drills, end mills, slotting saws, thread mills, engraving and spotting tools. The series is designed to increase productivity, remove material at higher rates, improve surface quality and extended tool life over a range of industry applications within the material groups.
The company will also feature its Utilis Multidec Cut3000 cutoff inserts with new geometries.
Buying a Lathe: The Basics
