Okuma
Vitrified Grinding Wheels for Centerless Grinding
Available from Fives, Gardner Abrasives vitrified grinding wheels are designed for efficient centerless grinding operations.
Available from Fives, Gardner Abrasives vitrified grinding wheels are designed for efficient centerless grinding operations. The high-performance wheels are well-suited for difficult-to-grind materials and enable better form retention, contributing to improved component finish in precision grinding of ferrous and nonferrous materials. The multipurpose wheels can be used in stainless steel, Inconel and titanium applications, among others, and are available in a variety of sizes.
  • Threading On A Lathe
  • Watchmaking: A Machinist’s View
  • 10 Things to Know About Creep-Feed Grinding
Okuma
Gardner Business Intelligence
