VMC’s Components Promote Speed, Accuracy
SMTCL Americas’ VMC850B is designed to provide power, speed and accuracy.
SMTCL USA, Inc.’s VMC850B is designed to provide power, speed and accuracy. It features a full FANUC package, including drives, motors, resolvers and a 0i control. It also uses a GIFU 24-position side toolchanger and a Spintech 10,000-rpm spindle with a high-quality rotary union for through-spindle coolant. The THK linear ways pump lube directly to the high-quality bearings. Other components include Hi-Win ballscrews, a Bijur lubricating system and Grundfos. The German casting design gives the machine a firm, rigid structure.
The 40-taper VMC can machine aluminum, cast iron, stainless steel, Inconel and titanium with good surface finish. The 50-taper version, with its ZF 2-speed gear box, can reduce cycle times and improve finishes for users machining titanium.
The machine has a maximum rapid feed rate of 1,250 ipm and a cutting feed rate of 787 ipm. The through-spindle coolant enables increased speeds while maintaining good finish, and deeper roughing passes reduce cycle time.
SMEC America Showcasing Machines' Reliability and Rigidity
SMEC America is running demonstrations on its machines both old and new at its IMTS booth, with engineers on hand to help answer questions.
Heavy Engineering: The Complex Logistics of Moving Large Machine Tools
One of our fascinations with large-format machine tools has little to do with their capabilities, but everything to do with the logistics involved with getting them up and running. Here’s how one of the world’s oldest builders of giant machine tools tackles the challenge.
