Turn Your Operational Gaps into Efficiency Gains
Sponsored ContentHere are five ways machine shops can improve throughput, spindle uptime and job changeovers without implementing more costly lights-out automation practices.
For many machine shops and manufacturers, the idea of making process, operations or equipment improvements on the shop floor can feel overwhelming. With changing customer demands, shorter lead times and a persistent labor shortage, it can be difficult to know where to begin. But making your operations more efficient doesn’t have to be disruptive or expensive.
The smartest approach is to start small and make targeted improvements that eliminate waste and increase efficiency and productivity. The key is to apply technology that can turn your operational gaps into efficiency gains.
Here are five practical steps to help you streamline operations and stay competitive without implementing lights-out automation practices whether you’re aiming to reduce downtime, improve consistency or get more output from your existing equipment.
1. Monitor performance with real-time data.
Start with assessing where you currently have efficiency gaps. Without visibility, it’s hard to identify what’s currently working and what’s not. Then, prioritize the gaps to fix them in order of the most impact. Tracking performance is essential.
The EZ-SmartTower allows operational managers to display and monitor up to 30 machines at one time from one centralized computer.
Machine tracking systems can provide real-time insights into cycle times, machine downtime, tool usage and more. This data helps prioritize improvements, justify investments and keep teams aligned around production goals. For example, Lyndex-Nikken’s EZ-SmartTower machine tracking solution for CNC lathes, mills and similar machines empowers machine shops to automate production data collection (i.e. uptime, idle time, error time, alarms, part making, operators and so on) so you can more easily perform data analysis to identify bottlenecks, make improvements, increase spindle time and enhance overall machine efficiency.
With better visibility, you can make decisions based on facts, not assumptions, as you fine-tune your processes.
2. Maximize machine uptime.
One of the most effective ways to increase productivity is to minimize spindle downtime. If a machine is not making chips, you are not making money.
Presetting tools offline is essential for manufacturers looking to optimize their workflow and maintain high levels of accuracy in CNC machining.
Manual tool setups at the machine are a common source of wasted time and human error. By moving this process offline using a tool presetter such as Elbo Controlli Nikken models, you can measure, inspect and set tools while the machine keeps running. This not only reduces delays but also improves accuracy and tool life due to more consistent setups which is especially important for shops that perform frequent setups or are experiencing scrap or rework due to tool errors.
If your machines sit idle during changeovers or setup, this is the first area to tackle.
3. Minimize setup and changeover time.
In today’s high-mix, low-volume environment, flexible setups are essential. Lengthy workholding set up and changeover time can severely impact throughput and on-time delivery.
With a Zero Point system, there is no differentiation between zero pins, floating pins, or free pins. Since only one clamping stud is required, set-up times are drastically reduced, and machine capacity is increased.
Implementing a Zero-Point clamping system enables fast and repeatable part changes. Operators can switch fixtures in seconds without re-indicating, significantly reducing non-cutting time and boosting shop floor productivity. The system streamlines the steps that consume the most time and attention, and it supports pulling a setup off the machine and returning to it later without losing location. Faster setup and changeover mean shorter lead times, improved scheduling through workflow efficiency and better use of existing capacity.
4. Improve part handling and workflow efficiency.
Once your machines are running more consistently, look at how parts are staged, handled and transferred between operations. Repetitive loading tasks, inconsistent timing and operator bottlenecks can reduce throughput.
The EZ-AutoCart machine tending solution empowers machine shops to automate the tending of CNC lathes, mills, and similar machines,
Mobile tending carts such as the EZ-AutoCart or flexible systems for machine tending such as the EZ-Cob are a simple way to keep workflows smooth. These tools can relieve overburdened operators and ensure machines stay supplied, especially during employee breaks or shift changes. Efficient part handling supports continuous cutting and improves overall flow without requiring major system changes.
With the EZ-Bot, a large number of jobs with different clamping devices and workpieces can be kept “ready to start” and immediately clocked in as required.
5. Reduce manual intervention between cycles.
Another area that slows down production is the amount of manual work required between cycles, such as blank part, vise and pallet handling. The lack of skilled workers is an industry challenge that further exacerbates this issue for most manufacturers.
Integrated machine tending systems that handle pre-defined tasks can help solve those problems. Small-footprint equipment such as the EZ-Bot automatic work changer that runs repeatable sequences with predefined programs keeps the process moving without constant operator involvement, which is especially helpful in shops juggling multiple parts and job types with limited skilled staff. The EZ-Bot can maximize machine running times while minimizing the time strain on skilled workers. Reducing these repetitive tasks for workers adds up to more spindle uptime.
Incremental Improvements Add Up
You don’t need a full process overhaul to get significant improvements in your shop. Small, strategic changes such as offline tool setup, quick-change workholding, improved part handling and machine performance tracking can have a big impact on your efficiency, productivity and ROI.
Making improvements to increase efficiency on your shop floor isn’t about adding complexity. It’s about removing the friction that slows your team and processes down.
For more information about Lyndex-Nikken machine tool accessories and machine tending solutions such as these to improve shopfloor efficiency, visit lyndexnikken.com.
