When Buffers Do the Work and When Your Process Should
From inventory and cycle-time margins to inspection and data flow, how improved process control is changing what buffers have to carry and what happens when they’re removed too soon.
View MoreAstronaut Edwin “Buzz” Aldrin steps onto the Moon during Apollo 11 in July 1969. The mission’s success depended not only on precision, but on built-in margin — time and fuel reserved to handle the unexpected. Source: NASA Office of Communications
As Neil Armstrong guided the lunar module toward the moon’s surface, the landing system began throwing alarms. The planned landing site with a name as smooth as glass — the Sea of Tranquility — was actually chock-full of boulders. As alarms blared and the clock ticked, Armstrong took manual control and searched for a new spot. Mission control would later determine that only 20 seconds of fuel remained when the Apollo 11 module finally touched down.
That extra fuel was a buffer to give the crew time when things didn’t go as planned. Without it, there is no landing, and one of the most consequential technical demonstrations of the Cold War fails in its final seconds.
Most manufacturing systems are built the same way, relying on buffers to absorb what they can’t fully control.
In manufacturing, these kinds of buffers take more familiar forms. Inventory is the most obvious example, including the Toyota Production System where work-in-process inventory is controlled in a manner that absorbs variation without masking potential problems. But buffers show up elsewhere, too: extra cycle time built into programs to avoid tool failure, inspection steps that happen well after machining, or layers of network infrastructure that translate between systems that speak different languages. Each one serves the same purpose as Apollo’s fuel reserve — absorbing variation and buying time.
The four features in this month’s issue point to a different way of stabilizing systems. Instead of relying as heavily on buffers, they show how improvements on the shop floor are changing how much those buffers have to do.
The clearest shift relates to how shops are rethinking inventory. In her reporting on Mach Medical, Julia Hider describes a system designed to produce orthopedic implants in lot sizes as small as one, cutting lead times from 20 weeks to three and enabling inventory reductions of as much as 85%. The tradeoff here is important: when inventory is no longer the buffer, the process itself has to be stable and responsive enough to deliver parts on demand.
The same pattern appears in Evan Doran’s reporting, but this time on a machine tool. Doran describes how high-performance cutting and high-speed machining strategies reduce the need for conservative programming margins — specifically by controlling for consistent tool engagement and chip load. The result is measurable: cycle times go down and material removal rates go up, but only if the machine, control and tooling can maintain a consistent level of stability under varying loads.
The pattern shows up again in inspection. In Doran’s cover feature, Acutec Precision Aerospace moved metrology onto the shop floor, cutting inspection time by roughly 80% and catching tool-wear drift within a few parts instead of well after the fact. Without that immediate feedback, unattended machining could easily have drifted into worst-case scenarios: producing scrap faster.
Finally, back at the system level, Hider’s reporting on single-pair ethernet points to a similar reduction in buffering, but this time in the form of gateways and translation layers between devices. A unified network architecture doesn’t just simplify wiring; it allows data to move directly from the shop floor to higher-level systems without the delays and potential friction that come with data handoffs between devices.
What ties these examples together is the shift in what makes them necessary. Buffers exist to compensate for variation, whether in demand, process stability, feedback or system connectivity. When those sources of variation are reduced or brought under tighter control, the need for buffers shrinks with them. The opposite is just as important: removing a buffer without improving control can expose a system to failure. Lower inventory without shorter lead times means material is consumed faster than it can be replenished. Faster cycle times without stable cutting conditions break tools. Unattended machining without in-process inspection produces scrap. Fewer network layers without reliable communication leave data stranded and unusable.
In each case, the buffer is not removed first. The control comes first.
Ultimately for shops, this month’s reporting offers a way to evaluate where buffers exist and why. In many cases, they are doing exactly what they are supposed to do: protect the operation from variability that hasn’t been addressed yet.
The opportunity is to be more deliberate about which buffers are carrying the load. If your inventory is high, is it covering for long lead times or is it because your output is inconsistent? If your programs are conservative, is it because the process isn’t stable enough? If inspection is happening after the fact, is it because the system can’t respond to drift in real time? And if data moves slowly through your organization, is it because your systems aren’t fully connected?
The examples in this issue strongly suggest that as control improves, those conditions start to change. Lead times come down so inventory can come down with them. Cutting becomes more predictable, so cycle time margins can tighten. Measurement happens in-process, so quality doesn’t have to be verified after the fact. Systems communicate directly, so information doesn’t need to be translated at each step.
Dialing in on where buffers exist and how large they need to be raises the bar for the underlying process. The shops that benefit will be the ones that build enough control into their systems that buffers stop doing the heavy lifting. When something unexpected does happen, the margin that remains determines whether you have time to respond at all.
WEBINAR: From Machine Data to Guided Action: How Modern Shops Are Closing the Execution Gap
In this webinar, MachineMetrics Product Manager Josh Fish is joined by Pindel Global Precision's Thomas Deslongchamps, for a candid look at what closing the execution gap actually looks like inside a precision machining shop.
