See the Steps Involved in Making a Quality Cutter
Scientific Cutting Tools outlines the processes and technology involved in manufacturing precision cutting tools for challenging machining applications.
Use of Zoller pomSkpGo enables SCT to inspect and verify critical tool geometry with a high degree of consistency. Source: Scientific Cutting Tools
In its West Building booth, Scientific Cutting Tools (SCT) tells the story of how the recent addition of three cutting tool manufacturing technologies helps it create high-performance cutting tools for myriad challenging applications. The company refers to it as its “Tech Trifecta,” which includes:
- Zoller inspection. Measurement equipment such as the Zoller Genius and PomSkpGo enables SCT to inspect and verify critical tool geometry with a high degree of consistency. By measuring features such as diameter, cutting geometry and edge consistency, SCT can better identify variation and confirm that a tool is ready for the next manufacturing step.
- ANCA precision edge preparation. SCT’s ANCA EPX-SF stream-finishing machine uses controlled granular media to hone and polish cutting tools at the micro level. The process creates a more consistent cutting edge and smoother surface before coating.
- CemeCon HiPIMS coating. With the addition of the CemeCon CC800 HiPIMS system, SCT brings advanced PVD coating capability in-house. HiPIMS, or High-Power Impulse Magnetron Sputtering, uses high-energy pulses to produce dense, smooth and strongly adhered coatings.
A tabletop display illustrates that tool manufacturing progression through four stages: inspection, preparation, coating and result. Using the same 15-degree helical thread mill throughout, SCT shows how greater control of geometry inspection, edge condition and coating contributes to a quality, finished tool.
Plus, a second tabletop display connects that manufacturing story to tooling focused on porting and thread milling. It features the company’s SAE J1926 and AS5202 port kits, the complete Versa-coated Port Mill lineup and representative thread mill families. And know that there’s also a raffle for as much as $500 in SCT tooling, giving one attendee the opportunity to put the featured porting or threading technology to work in his or her own shop.
Emuge-Franken Skiving Tools Improve Precision for Tool Grinding Machines
Emuge-Franken USA is showcasing its line of clamping and skiving tool solutions, designed to improve precision and accuracy in tool grinding machines.
Sandvik Coromant Highlights End-to-End Machining Solutions
IMTS 2026: Sandvik Coromant presents comprehensive tooling, digital solutions and expert support to address real-world manufacturing challenges.
DN Solutions AM2CNC Platform Integrates Additive Manufacturing and CNC Machining in Single Workflow
IMTS 2026: DN Solutions demonstrates the AM2CNC platform, showcasing the DLX 450 metal additive system and DVF 5000 second gen five-axis machining center working together to take metal additive preforms through to finished, ready-to-use parts.
