AutomaTech Expo
Protect Your Automation by Avoiding Material Inconsistencies
Material inconsistencies can doom an automation integration as surely as incorrect tooling or cutting parameters. What should shops look for in an automation-ready material?
Automation alone does not guarantee consistent or profitable outcomes. When machining processes run unattended, the margin for error becomes extremely small. The slightest inconsistency can cascade into scrapped parts, broken tooling or unexpected machine downtime. As a result, successful automation also depends on a critical but often overlooked factor: the consistency and preparation of the material entering the machine.
A robot setting down a finished part before picking up a blank to place in a CN Solutions machine.
To ensure reliable robotic performance, material blanks within a part run should be of the same weight, with balanced geometries and consistent gripping surfaces. Images courtesy of Fastems.
In non-automated machining, experienced operators often compensate for inconsistencies in raw material stock. If a plate arrives slightly oversized, out of square, or warped, a skilled machinist can make adjustments during setup, alter tool paths or perform additional machining passes to correct the issue.
But automation fundamentally changes that equation. In automated machining cells, machines may run unattended for hours at a time. There is no operator standing by to correct problems or adjust setups between parts. Every element of the process must perform consistently across hundreds or thousands of cycles. Any variation in the starting material can disrupt that repeatability, so automation-ready materials must show geometric and chemical consistency from heat to heat. By addressing variability at the very beginning of the manufacturing process, these materials help ensure that automated systems run smoothly, predictably and efficiently.
Inconsistent Material Causes Errors
Common problems associated with standard mill stock include warping caused by internal material stresses, thickness variation across plates, non-parallel or non-square surfaces, inconsistent hardness from improper heat treatment and dimensional inaccuracies that complicate workholding.
In unattended operations, these issues can quickly lead to serious problems, such as errors in robotic part loading, improper clamping pressure, tool breakage and dimensional errors, any of which can interrupt production runs. Instead of improving productivity and lowering costs, automation under these circumstances causes just the opposite.
“Automation is incredibly capable, but it’s also unforgiving,” says Robert Humphreys, retired area sales manager for Fastems. “When you remove the operator from the process, you remove the safety net. If the material entering the machine isn’t consistent every single time, the system will eventually expose that weakness.”
Developing a Materials Strategy for Automation
A successful automation strategy begins long before the first part reaches the machine tool. It requires direct collaboration between material suppliers, manufacturing engineers and shopfloor managers to ensure that material preparation aligns with the requirements of the automated system.
“Automation demands predictability,” says Ben Belzer, president and CEO of TCI Precision Metals. “The more variables you can eliminate upstream in the manufacturing process, the more reliable your machining operation becomes. That starts with the material itself.”
This process begins with selecting the appropriate material type and grade for the application. Different alloys behave differently under machining conditions, and shops must consider factors such as strength, hardness, thermal stability and machinability.
A machinist attaching a blank to a tombstone in a machine tool
While operators can adjust processes for minor dimensional variances in blanks during staffed operations, this is not possible for lights-out operations. Consistent lights-out success, especially for high-precision parts, requires materials with consistent dimensional and chemical properties.
Heat Treatment and Stress Relief
Internal stresses within metal plates can cause unexpected movement during machining. As cutting forces remove material, these stresses are released, sometimes causing parts to warp or distort. In manual machining operations, operators can often correct these issues during setup or secondary operations. In automated environments, however, uncontrolled movement can result in scrapped parts or machine faults. “When parts move during machining, automation doesn’t know how to react,” Humphreys explains. “The machine is doing exactly what it was programmed to do. If the material moves unexpectedly, the machine can’t compensate for it.”
Proper heat treatment and stress-relief processes help stabilize materials before machining begins. By reducing internal stresses within the metal, manufacturers can achieve far more predictable machining behavior.
Precision Pre-Machined Blanks
Another critical component of automation-ready materials is precise blank preparation. In automated machining systems, robotic handlers typically load parts into fixtures, vises or palletized workholding systems. For this process to work reliably, blanks must arrive with consistent geometry, predictable edge conditions, reliable gripping surfaces and controlled dimensions. “Automation systems are designed around repeatability,” Humphreys explains. “If the robot expects a certain size part and suddenly that dimension changes, the entire system can be affected.”
Pallets in a flexible manufacturing system
Though machines and tooling are important for lights-out work, success relies on materials that can also live up to the challenge. “If you want to run machines overnight or through the weekend, the process has to be rock solid,” Humphries says. “Material consistency is a big part of achieving that.”
Methods for controlling blank geometries include precision sawing to near-net dimensions and grinding or milling to exact thickness, with inspection confirmation for tight dimensional tolerances, squareness and parallelism. Belzer notes that this preparation stage can dramatically influence machining efficiency. “If machinists have to spend time squaring plates or correcting inconsistent stock, you’ve already introduced variability,” he says. “Pre-machined, automation-ready blanks eliminate that step entirely and allow the process to begin from a stable starting point.”
Dimensional Consistency
Belzer stresses that consistent blank dimensions are fundamental to reliable automation. “Automation only works when every part behaves exactly the same,” he says. “Dimensional consistency from blank to blank is what allows manufacturers to trust that their process will run unattended.”
Even beyond setup, the consistency of automation-ready blanks is necessary to achieve high performance from CNC programs. These part programs assume a consistent starting surface. When blank dimensions vary, tool paths may remove too much (or too little) material, throwing the part out of tolerance. Automated probing routines also rely on predictable geometry to establish datums, and metrology machines may crash if material is present where it is not expected.
Automation-ready blanks stacked on a pallet, with layers of packaging between them
TCI recommends checking material providers’ shipping processes in addition to production processes. For example, TCI individually packages each of its blanks to lower the odds of any blank being damaged or scratched during the transportation process.
Reaching Automation’s Full Potential
Automation remains one of the most powerful tools available to modern manufacturers. It enables higher productivity, reduced labor dependency, and the ability to compete in a demanding global market. But automation only performs as well as the inputs it receives.
“Automation magnifies everything,” Humphreys says. “If the starting material is consistent, the process becomes incredibly reliable. But if the material varies, the machine will repeat those problems again and again.”
Consistent, high-quality materials form the foundation of successful automated machining. Automation-ready blanks eliminate variability, stabilize machining processes and allow advanced manufacturing technologies to operate at their full potential.
For companies investing in CNC machining centers, robotic handling systems and multiaxis automation platforms, the material supply strategy should be a central component of the overall manufacturing plan, not just an afterthought.
Save the date! Mexico’s Automation solutions event
Deublin
Master Fluid Solutions
Paperless Parts Demo
WEILER
Makino EDAf2i Ultra
SGS
Sponsored
Factory Orchestration System Adds Clarity, Accountability and Accuracy to Shop Floor
Factory orchestration technology organizes shopfloor data to automate non-productive labor time, solidify process control and ensure ERP ideals match shopfloor reality.
Sponsored
Robotic Cells Transform Archery Bow Manufacturing Efficiency
Mathews Archery boosted bow riser production by 25% through robotic automation with CNC Solutions. Overcoming labor shortages, the system enables unattended weekend runs, halves scrap, and delivers 1.5-year ROI.
Sponsored
Exploring Automation at IMTS 2026
IMTS 2026 showcases affordable automation for manufacturers, from cobots to AI-driven systems, helping SMEs boost productivity, quality, and unattended production with low-risk financing.
Sponsored
Addressing Manufacturing Challenges with Automation
GrayMatter Robotics’ Physical AI robotic cells for manufacturing offer immediate impact and results.
Aerospace
How Precision Blanks Help This Aerospace Shop Build Better Parts
Internal stress in thin metal parts can lead to warped components and scrapped work. Matrix Machine found a better way by sourcing precision-ground blanks from TCI Precision Metals. Here’s how that decision freed up capacity and made critical parts more predictable.
Workholding
Automotive dies and die inserts are often complex, one-off parts with little room for error. Integrity Tool's investments in modular workholding tools and 3D optical scanning have allowed the company to create niche capabilities for its CNC machined parts.
Automation
Shop “Dims the Lights” With Pallets and More
Adding pallet systems brought Mach Machine success and additional productivity. The shop has since furthered its automation goals while adding new capabilities.
AutomaTech Expo
