MP Systems' Purge Keeps Machine Tool Coolant Tanks Clean
Westec 2019: MP Systems will display its Purge coolant filtration system designed to keep a CNC machine tool’s coolant tank filled to maximum capacity with clean coolant.
MP Systems will display its Purge coolant filtration system designed to keep a CNC machine tool’s coolant tank filled to maximum capacity with clean coolant. It pulls coolant from the dirty side of the coolant tank, filters it, and returns it to the clean side of the tank faster than the flood and high pressure coolant pumps draw from it. This prevents coolant starvation of the machine’s flood and high-pressure coolant pumps and keeps small chips and fines from clogging the machine tool’s nozzles, lines and screens. By keeping the coolant clean, part quality is improved and cutting tool life is extended, the company says. As a bonus, the machine’s coolant tank doesn’t need to be cleaned nearly as often.
“Cleaning a coolant tank is a nasty job that nobody wants to do,” says Systems Engineer Brian Jalbert. “It’s time consuming, and you have to shut the machine down to do it. If the machine is inside a caged cell, it’s a task that can take days. If you can eliminate this job even once, the Purge will pay for itself.”
MP Systems will also display its VR8 Variable Volume High Pressure Coolant System.
Hennig Inc. Acquires Industrial Coolant Systems
ICS develops and field tests high-pressure coolant systems, coolant filtration systems and other machine tool solutions.
High-Speed Videos Analyze Machining Processes in Fine Detail
Blaser Swisslube captures the machining process, chip formation and behavior of its Synergy 735 metalworking fluid through high-speed, macro photos and videos.
