Additive Manufacturing's Relationship with Design
AM offers new possibilities for design but also introduces challenges. The latest issue of Additive Manufacturing magazine explores the relationship between the two.
Additive manufacturing (AM) is changing design. Along with expanding the range of designs that are possible to manufacture, it is changing how we think about design’s role, where design falls in the manufacturing process and what “design” actually entails.
That’s because the design in AM determines not just the end performance of a 3D-printed part, but also how it will build—whether it will warp, develop the right material properties or print within tolerance. Design is, likewise, beholden to what happens after the print. Can loose powder be fully evacuated? Can the support structures be removed without damaging critical features? Does this part need machining allowances or workholding features? When design is an integral and pervasive component of the additive manufacturing process, the result is a successful build that can be efficiently post processed and go on to serve its intended purpose.
The dynamic between AM and design is the focus of the latest issue of Additive Manufacturing magazine. The cover story, for instance, explores how General Motors (GM) is using generative design tools from Autodesk and 3D-printing technology to create parts such as the seat bracket pictured on the cover. This proof-of-concept part is 40 percent lighter and 20 percent stronger than the original assembly of eight separate components. GM went through more than 100 iterations to arrive at this design, which was selected for its manufacturability in addition to its light weight.
Design’s expanded influence in AM is also demonstrated in other stories in this issue:
- the creation of a topology optimized hip stem implant, customized for a specific set of activities, through a recursive design process;
- how a manufacturer eliminated assembly and improved performance of an oil reservoir by redesigning it for 3D printing; and
- metal AM’s role as a prototyping and production tool, often simultaneously, for a Formula One racing team.
Want to learn more about 3D printing?
Sister publication Additive Manufacturing explores how manufacturers are applying 3D printing to make tooling, molds, functional prototypes and end-use parts. Subscribe.
4 Ways 3D Printing Is Changing Medical Implants
Additive manufacturing provides new ways of making medical implants, but its impact is greater than this. How 3D printing is changing medical manufacturing and improving patient outcomes.
Digital Thread Enables First-Time-Right 3D Printing
Using Topology Optimization to Lightweight: A Paradox for Machining
Today’s computer software can just as easily generate lightweight shapes for subtractive processes as it can for additive ones, but it increases cost and waste to make them.
