Kitamura
CNC Milling Tips & Tricks: 7 Articles For You to Mill Through
Dive into popular milling articles from Modern Machine Shop, Moldmaking Technology, and Production Machining to discover tips, tricks, and innovations that will make your chips fly—and your competition sweat.
Want to take your milling skills to the next level? Whether you're aiming for faster cycle times, tighter tolerances, or smoother finishes, we've got you covered. Our curated collection of milling articles is packed with expert insights—from thread milling techniques to chatter prevention—to help you refine your process and achieve better results. Stay sharp with these essential tips for every machinist's arsenal!
How Process Damping Impacts Milling Stability
Modern Machine Shop
Graph showing spindle speed vs. axis depth
Source: Tony Schmitz
Process damping is a phenomenon that can increase milling stability at low cutting speeds and is affected by the cutting edge design.
Hybrid Milling/Drilling Machine Reduces Total Mold Machining Time
Source: MSI Mold Builders/Creative Technology Corp.
MSI Mold Builders now squares, plus drills and taps eye-bolt holes on 50% of its tools in a single setup using a five-axis milling/drilling center with a universal spindle.
Thread Milling Tips for Tricky Aerospace Materials
Source: Allied Machine and Engineering
Compared to tapping, thread milling offers advantages for creating threads in challenging materials such as high-temperature alloys.
Applying Machine Learning for Milling to Prevent Chatter
Modern Machine Shop
Machine learning is used to predict system behavior based on process data. It can be used to model milling behavior and improve performance.
Select End Mills With Mold Material, Features and Machining Process in Mind
Solid carbide end mills with unique geometry and chip breakers designed specifically for trochoidal milling.
Source: EMUGE-FRANKEN USA.
Here are some factors to consider when choosing cutting tools for pre-roughing, hard milling, steep walls and tough materials.
When a CNC Turn-Mill Doesn’t Turn
Source: MoManTech
A shop in Big Sky Country uses a B-axis multitasking machine to produce complex, prismatic medical parts that require no turning complete from barstock.
Modern Machine Shop
Source: Getty Images
Kitamura
Gravotech
EMUGE FRANKEN
IMTS 2026
Dimensional Air Gage Specialists
Kitamura
