Blum-Novotest Competence Center Supports Lights-Out Automation
Blum-Novotest recently opened its new Competence Center in Erlanger, Kentucky. Inside, the company plans to run a training and technology hub for the U.S. market — especially supporting the growth of lights-out automation. Find out how below.
An ability to machine long part runs unattended is rarely at issue in the automation applications Modern Machine Shop covers. Far more often, the limiting factor on any automation capability is the ability to ensure quality on an unstaffed machine for many hours. Metrology and measuring technology company Blum-Novotest intends to push this factor as far as it will go, using its new competence center in Erlanger, Kentucky, to perform software development for relevant machine controls, as well as training, product management, repairs and assembly for for the U.S. manufacturing market.
Alexander Blum and Lillian Barraud on-stage at the Blum-Novotest Competence Center opening.
Alexander Blum (left) and Lilian Barraud (right) hosted the opening of Blum-Novotest’s new Competence Center in Erlanger, Kentucky, on June 26, 2025. The pair say the new center is meant to prove the company’s dedication to the market, and they hope it will help them expand local sourcing and repair capabilities. Image courtesy of Blum-Novotest.
Building the Foundation for Competence
Alexander Blum, CEO of the Blum-Novotest Group, says a key differentiator of the company is its close relationships with and responsiveness to its customers. Maintaining this responsiveness across the globe was a key factor behind the start of Blum-Novotest North America in 1997, with the division’s main goal being to provide local support for imported equipment. This quickly expanded to a retrofitting service and more, and has led to a larger permanent presence visible in the new Blum-Novotest Competence Center, which hosted its grand opening on June 26, 2025.
Blum says this new competence center is meant to provide assurance that the company is committed to the U.S. market, and will be a hub for training, custom solutions, repairs (complete with local sourcing where possible) and some assembly. It includes machines with controls from different providers, such as a FANUC control on a RoboDrill from the same company, a Siemens SINUMERIK ONE controller on a Heller five-axis Tokn machine and an Okuma control on an Okuma Genos M460V-5AX five-axis mill, using these to both demonstrate the compatibility of Blum-Novotest’s products and provide training to users of these and other control types.
This training will cover both theoretical and practical aspects of the metrology and measurement equipment. In a dedicated training room, visitors can review specifications for their equipment — which Blum says is useful for both first-time buyers and shops whose operators are hesitant to trust the equipment — while the showroom floor acts as a place for trainees to practice operating the equipment and learn how to most effectively use Blum-Novotest technology.
For example, Blum-Novotest’s FormControl X measuring and automation software enables users to measure a part, see the difference between nominal and real measurements after machining, and automatically compensate the machine for the next part. The software also keeps track of data for traceability and statistical process control.
The interior of a five-axis vertical mill, with Blum-Novotest equipment retrofitted next to a trunnion table.
Blum-Novotest’s equipment is compatible with three-axis mills, five-axis mills, lathes and mill-turn machines, either installed at the time of purchase or retrofitted afterward through custom brackets. Image from Evan Doran, Modern Machine Shop.
Simple Self-Optimization
The central Blum-Novotest equipment on the competence center floor is the LC50-Digilog. The LC50-Digilog has long been able to measure tool length and radius, but Blum says the laser is now able to check the entire contour of a single or all cutting edges at any spindle speed. He says this has become more important in recent years, as even the tiny differences tools can show coming off a tool grinder — even down to the micron level — can make a difference in high-precision aerospace or energy industry work.
Blum says the laser can identify runout and form deviations, sending the data back to the paired LC-Vision software. From here, the software uses this data to optimize tool offset, instructing the machine to automatically compensate without requiring operator action. Blum calls it “self-optimizing compensation,” as it automatically updates as the tool wears.
A tool changer in a Fanuc machine, with the table of a mill below.
In addition to tool and part measurement, Blum-Novotest equipment can measure machine kinematics. This is aided by the company’s KinematicsPerfect software, which Barraud says can enable users to check, compensate and set machine kinematics without external assistance. Image by Evan Doran, Modern Machine Shop.
Lilian Barraud, president of Blum-Novotest North America, gives one example of this for a customer consistently experiencing scrap after shift changes. In this case, the machine spindle and tool would cool off just enough between shifts to cause errors in high-tolerance work. Blum-Novotest introduced the customer to a real-time laser monitoring system that monitors tool length variation down to the micrometers while the spindles warms up, only releasing the tool to begin the cutting operation once tool length has stabilized.
Blum and Barraud say this sort of self-optimizing equipment works as well for full lights-out automation as it does for shift changes. They also encourage the use of the laser system to check spindle performance, saying it can help users predict spindle life and schedule maintenance before a machine goes down, potentially saving days of downtime and expensive scrap.
Blum says that the company’s primary goal is to not only improve the quality of individual processes, but to support the closed loop automation of the full manufacturing process. This means ensuring parts come off the machine correct from the very first part. By training and working with users to use equipment for optimizing machine and part performance, Blum-Novotest aims to make its new competence center instrumental to this goal.
EMUGE FRANKEN
Dimensional Air Gage Specialists
IMTS 2026
Gravotech
Measurement
Measurement
More Surface Finish Parameters at Hand
Measuring surface finish at the point of manufacture is often done by the same machinist who is manufacturing the part. They need tools that meet test requirements and are easy to use.
Measurement
Orthopedic Event Discusses Manufacturing Strategies
Measurement
Turning Fixed-Body Plug Gages Inside Out
Fixed-body mechanical plug gages provide fast, high-performance measurement for tight-tolerance holes.
Automation
Blum-Novotest Measurement Software Accelerates Automation
IMTS 2024: Blum-Novotest announces the FormControl X measurement software, which includes an alignment function that can interact with unmanned operations and in cooperation with robotic solutions.
IMTS
See Automated Workpiece Measurement in Real Time
User-friendly inspection software for CNC machining centers is shown monitoring measurements between and after machining while performing SPC based on recorded measurement values.
Inspection and Measurement
Prime Technical Services Monitoring Solutions Support Lights-Out Manufacturing
PMTS 2025: Prime Technical Services Inc. showcases CNC tool monitoring and process control from Caron Engineering, as well as smart manufacturing solutions from Blum-Novotest Inc.
