Iscar
Turning the Corner on Virtual Machining and Simulation
Simulation software’s effectiveness comes down to proper implementation and alignment with shop priorities.
Source: Way of the Mill LLC
Reader Question: Our shop has adopted more complex equipment including five-axis mills and multitasking machines. Through some growing pains, we now know we need more robust simulation software but are uncomfortable with the cost. Can you help us turn the corner on this decision?
Miller’s Answer:
While simulation software has been around a while, admittedly I did not adopt it myself until more recently. Given my more production-focused background, I would perform my due diligence in the CAM environment, then do a careful prove out at the machine, but the process likely would run with the same program, workholding, tooling, in the same machine for one-to-five years. The utility versus cost of simulation software in my previous role was a much different equation than now, where I turn over different work for diverse customers in varying industries.
Today, I consider it a must for job shops, as it speeds up the parallel processing of work on the machine and the work in the office. Even more production-oriented shops are turning over more work across more hours on more complex machinery than ever. Due to the speed of CAM, automation and market demand, all of this happens at a breakneck pace, and often overnight when no one is around. Therefore, simulation tools as an aid and an insurance policy against that speed are a must.
As far as the hesitation for adoption, I suspect the hesitation to your concern is mostly cost, which is valid, but may also stem from perceived complexity with these packages and what they can or can’t do.
Regarding cost, yes, they can be very pricey, but I’d recommend not viewing it as software, but as an insurance policy for your machines. For example, you may need less insurance for a three-axis mill, as it has less risk factors for an expensive crash. Generally speaking, only the tool and vise can collide under normal conditions. Most three-axis machines can’t reach the spindle face to the table. However, a five-axis machine can crash into itself, such as spindle housings hitting rotary tables at odd angles. Since your shop has also adopted multitasking machines, this risk of collision may be even higher with spindles, subspindles, turrets and more all working in parallel. On the three-axis, catastrophe may only cost the spindle, but on the five-axis it could cost the spindle and rotaries, and the multitasking could require an entire rebuild. Therefore, the level of insurance you may or may not require changes. Compare the cost over time of the software, and the cost for an incident you are protecting against.
As far as complexity, there are layers to this as well as types to consider. First, verification software has two main types, which are “toolpath simulation” and “post simulation.” The industry has several terms for this so you may see other names, but essentially toolpath simulation just simulates the motion as generated by your toolpaths before being post processed into usable G and M code. This is more typical when the simulation is part of the CAM package itself. Post simulation means the simulation uses the G and M code and runs it in a virtual machine as if it were running on an actual machine. Both have their merits.
If you have multiple machines, types of machines, controllers and programmers, you may consider separate software, which simulates the actual code. If you have a smaller portfolio of machines and you trust your postprocessor for these machines, then toolpath simulation can work just as well.
Regardless of the type of simulation you may choose, they have the same primary function, which is crash prevention. However, there are many other benefits you may be overlooking, which could solidify your decision. First is training and allowing new machinists and programmers to take their lumps in the virtual world versus the real world. Another is optimization, because things often look different in real machine motion as opposed to the CAM environment, which is often just a visual of the material and carbide. A third benefit can be utilizing simulation for quoting purposes. Often simulation does a better job capturing actual machining time, because it’s including non-toolpath motion more accurately, and it has the added benefit of confirming stroke limits. Again, something might look reasonable in the CAM environment, but your perception of the workpiece when its in the machine could be quite different, and be the difference between a good profit or a loss when things don’t work out.
Balance this with some reality. Simulation is not a cure all for poor practices. The tools in the machine must match how they were setup in the virtual world, and the workholding must match as well.
Simulation software can be a game-changer for process security, efficiency and cost savings. For shops handling complex, high-value parts or running lights-out operations, it offers an essential layer of protection and optimization. However, smaller shops with simpler work may not see the same return on investment. Like any tool, its effectiveness comes down to proper implementation and alignment with shop priorities. If your shop is exploring virtual machining, take the time to assess the complexity of your parts, the cost of errors and the potential gains in efficiency before making the investment.
CERATIZIT MaxiMill S-Power face mill for cast iron
Iscar
Allied Machine & Engineering
IMCO POW-R-FEED M935
Cut cycle times with Scientific Cutting Tools
Master Fluids Free Trial
Horn USA
Ingersoll Cutting Tools
Sponsored
The Smarter Way to Take Full Control of Your CNC Machine Shop
Designed to bridge the gap between CAM programmers and shop floor operators, SolidShop provides a seamless, real-time solution for managing G-code, tracking production and eliminating costly mistakes.
Cutting Tools
Orthopedic Event Discusses Manufacturing Strategies
CAD/CAM
Large-Format Machining With Small Cutting Tools and Dynamic Motion
Napoleon Machine, a defense contractor that provides parts for the M1 Abrams tank, recently took advantage of a CAM feature that allowed the company to streamline its cutting strategies and program offline. Here’s how the shop cut cycle times nearly in half with its large-format five-axis machining operations.
Medical
Five-Axis CAM Strategies Cut Cycle Time for Two Shops
After being acquired by the same parent company, two shops found that working together and sharing knowledge improved both of their bottom lines.
Measurement
OEM Tour Video: Lean Manufacturing for Measurement and Metrology
How can a facility that requires manual work for some long-standing parts be made more efficient? Join us as we look inside The L. S. Starrett Company’s headquarters in Athol, Massachusetts, and see how this long-established OEM is updating its processes.
