Video: Apply Metal and Machine It With Hermle’s Metal Powder Application (MPA) Process
The Metal Powder Application (MPA) process uses cold spray to apply metal to an existing workpiece. Because the material deforms rather than melts, MPA opens new possibilities for functional grading and other multimaterial applications.
Machine tool builder Hermle is known for its high-precision milling systems, but the company also offers part production services using a platform that combines this expertise with metal 3D printing. A subsidiary based in Germany is focused on operating the Metal Powder Application (MPA) process, a hybrid manufacturing strategy that combines five-axis milling with cold spray deposition. The process supports the precise addition of material, such as conformal copper areas added to injection mold tooling to improve cycle times. MPA also enables the creation of complex internal geometries, functionally graded materials, and, because of the cold spray process, even the inclusion of other components such as sensors. This video filmed at IMTS 2024 describes the process and showcases several representative case studies (despite operating the MPA process for nearly a decade, this event represents the first time Hermle has showcased it at IMTS – The International Manufacturing Technology Show).
Related Resources
- More on the MPA process
- Another cold spray application for embedded electronics
- More on the advance of hybrid machine tools
Transcript
Most hybrid machine tools use a welding like process to apply metal material in sequence with machining. But what if you could strategically apply functional materials without melting?
I'm Stephanie Hendrixson with Additive Manufacturing Media here at IMTS 2024 in the Hermle booth. Hermle is known for its high precision machining centers, but it also has a subsidiary focusing on providing hybrid manufacturing services through 3D printing and five axis milling on the same machine. The additive process is called MPA or Metal Powder Application.
Hermle provides MPA services using four machines that it designed and created itself, located in Germany. This is actually the first time that this technology has been displayed at IMTS in North America.
So MPA works by using compressed air to fire particles of material at an existing substrate or part. The powder is accelerated to very high speeds and fired at a pre-heated workpiece. The particles deform and bond to the substrate as well as each other, so you end up with high density, low porosity metal that can be machined almost right away.
Initially, most applications for MPA had to do with conformal cooling, introducing copper into mold tooling for heat dissipation to improve cycle times. But now MPA can be applied with copper, as well as tool steel, stainless steel, Invar and many other materials. And the customer doesn't have to choose just one. You can actually do functional graded materials by changing the mix of powder that is being applied to the part. MPA can even be applied to produce ceramic matrix composites, where they can add up to 30% ceramic powder into the mix.
Hermle also uses a support material for parts with complicated internal cavities or other structures. This satellite waveguide, for instance, has this complicated internal geometry. During manufacturing, these cavities would have been filled with that material, which was then washed out later.
And because there's no melting involved, MPA opens up the opportunity to incorporate sensors, thermocouples, other components into your hybrid manufactured parts. For instance, this semiconductor frame is made of Invar with these copper tubes. Hermle machined channels, placed the copper tubes and then printed Invar over top to fully enclose them and produce this finished assembly.
Using this process, material can be applied in five axes and can be used very minimally just to add functionality to the specific places where you need it.
If you'd like to learn more about MPA or other types of hybrid manufacturing
technologies, you can find a link to our collection of stories in the show description. You can also follow Additive Manufacturing Media
wherever you're watching and sign up for our newsletter, The BuildUp, to stay up to date on new technologies and applications.
About the Author
Stephanie Hendrixson reports on 3D printing technology and applications as executive editor for Additive Manufacturing. She is also co-host of The Cool Parts Show, a video series that highlights unique, unusual and weird 3D printed parts, and co-host and creator of the AM Radio podcast. SUBSCRIBE HERE
Machine Tool Drawbar Made With Additive Manufacturing Saves DMG MORI 90% Lead Time and 67% CO2 Emission
A new production process for the multimetal drawbar replaces an outsourced plating step with directed energy deposition, performing this DED along with roughing, finishing and grinding on a single machine.
Read MoreDigital Transparency in Machining Key to Multi-Site Additive Manufacturing
Cumberland Additive’s CNC programmer in Pennsylvania spends most of his time writing programs for machine tools in Texas.
Read MoreDesigning a 3D Printed Part with Machining in Mind
Designing extra stock and mounting features into a 3D printed part can aid in machining processes downstream.
Read MorePush-Button DED System Aims for Machine Shop Workflow in Metal Additive Manufacturing
Meltio M600 metal 3D printer employs probing, quick-change workholding and wire material stock to permit production in coordination with CNC machines.
This Rocket Fuel Injector Is a Solid Part That Contains a Working Motor: The Cool Parts Show #1
Our new video series debuts with a look at a solid metal part made through additive manufacturing that was built with a motor embedded inside. The motor sealed within the part adjusts the rocket’s fuel mixture while the rocket is in flight.
Read MoreThe Cold Spray Solution to the Casting, Forging Supply Chains
Startup HAMR Industries performs additive manufacturing work at Neighborhood 91 that provides an alternative to traditional casting and forging. Success so far has led to redefining the limits of its additive equipment.
Read MoreHermle Combines Metal Powder Application Process with Five-Axis Machining
Hermle integrated its MPA technology, a process where metal powder is applied by kinetic compacting to build completely sealed materials, in a Hermle five-axis machining center to create parts with highly complex inner geometries.
.jpg)
